looking for 16" inch alloys for 56 2L Avensis d-4d estate
bonnie&rocco
hi, ive recently brought an Avensis d-4d estate and have been having trouble finding the right alloys for as i understand the fittings may be different for saloon and estates, if anyone has a set for sale or could give me advice on what i actually need id be most grateful.
thanks
Hi John, welcome to TOC 🙂
afaik fitments for saloon/hatch/estate of the same engine are the same however they do vary between engines.
2.2 D4D & 2.4 petrol use 5x114.3 PCD, all others 5x100
hi, thanks for the info, ive found some 17s alloys, 7j 17h2 et 45, and they've come with 225/50 r17 tyres, will they be ok?
afaik should be but your speedo will read ~3.8% lower than it would with the 205/55 r16 that I believe were the tyre for a 2003-2006
ok, il be doing all the brake disc's and pads this weekend so il find out for sure then. fingers crossed.. and thanks for your time
you should also inform your insurance company of the modifications. Depending upon the company they may or may not charge.
