Yaris audio system
JemmaLT
I'm having issues with my 63 plate Yaris audio system. I get a white screen come up with a blue band across the top saying version up! Insert USB. and I literally cant do anything with the screen at all. It's stopped the use of phone connection, satnav and reverse camera as well.
Tried disconnecting Battery and reconnecting, as well as checking all fuses but still no luck.
Taken it to Toyota Peterborough but they were not particularly helpful- They did say its not in need of a software update though.
I hoped someone here might have some ideas about what the problem is or how to fix it?
  • 1 year later...
hi
i have same problem today
2013 yaris
did you find any solution?
Can you get into the hidden menu
Press and hold the setup button and turn the headlight on and off 3 times
