On-foot-off switch
Taurus 9
Hi Guys,
Just bought a 2011 Avensis xi Wagon.
Does anybody know what is the "ON -FOOT-OFF" small round switch for ?
Also, is there a recommended service interval for its CVT fluid ?
Hi Vlad, welcome to TOC 🙂
Can you post a photo of it & where fitted? It doesn't sound like something that is fitted in the UK.
Hi Scott,
Thank you for your reply.
It is just below the steering wheel, right hand side.
Seen on other Japanese imported Avensis as well.
The Avensis was only built in Europe (UK) and models for the Japanese market were exported From the UK.
  • Haha 1
Here in NZ, most cars are imported from Japan
22 hours ago, Heidfirst said:
On 8/28/2019 at 7:30 AM, saxo265 said:
Parking brake switch?
Only other mention that I found was https://priuschat.com/threads/on-foot-off.156270/
Does your car have footwell illumination & is that it?
Hi Scott,
Seen that forum as well. It does nothing for the illumination.
On or off, the light will be there when the driver door is open.
It does nothing for the parking brake.
No dash display either. Had a look at the interior illumination, but no difference, on or off.
Checked the hand brake function, but seen no difference. Strange ?
52 minutes ago, Taurus 9 said:
Hi Scott,
just to be clear, this would not be for the overhead light but for ambient lighting in the front footwells that can be on even with the door shut (e.g. my 2012 Avensis T-Spirit had it but that was controlled from the head unit iirc.).
No, not the overhead light certainly. The switch (on or off), will do nothing for the ambient light, and has no effect on the parking brake either.
Since I do not have the original manual, can not determine its function. Hopefully, someone will know ?
Other question is about the CVT Fluid. At how many kilometers does Toyota recommend a replacement ? There is no dipstick to be found, so guess it is sealed.
2011 Avensis Wagon, Engine: 3ZR - Chassis: ZRT272
  • 1 year later...
Did you ever find this out? I'm wondering the same thing .
Toyota NZ recommends replacing automatic transmission or CVT fluid every 6 years or 90,000km.
  • 2 months later...
Quote
Has anyone discovered what this on-foot-off switch is for yet?
We just bought a Japanese import 2009 Wish 2L and it has the exact same, seemingly no-function switch below left of the steering wheel.
it doesn’t seem to change foot lights or door lights.
  • 10 months later...
This turns on or off the footwell lighting on both sides when the headlights are on. It only comes in effect when the headlights turn on. It doesn’t change the footwell light when driver’s door is open. Hope this helps.
