Air con on 2019 corolla hybrid
Cbatoday
Just turned the ac on whilst driving in town
I expected the petrol engine to cut in to drive the power steering pump but it didn't
It must therefore be driven off the cvt gearbox. Anyone know any more...
It’s some type of electronic system but I’m  sure someone will be along shortly with a more technical answer.
Just imagine though it were run by the engine it would never switch off especially in really hot climates.
It's powered by the Battery. There's nothing particularly clever about that. Most A/C systems around the world are powered by electricity. The only reason most vehicles drive via a belt from the engine is because it's cheaper as there's no need for a dedicated electric pump and since the engine is always running it might as well do a bit more work, especially true at idle.
