JPtrio 0 Posted September 5 Hi all, hopin someone could help, had a blowout on my 2004 Estima and when I came to put the spare wheel on it doesn't fit (grrr), have been around local breakers to try and get a wheel that fits but not having much luck, does anyone know what other Toyota models wheels will fit the Estima (17")? Thanks in advance Quote Share this post Link to post Share on other sites
flash22 68 Posted September 5 All you need to know is the, Size, number of studs, pcd, offset and the centre bore (very important) i will have quick look and see what i can find Edit. 5x114.3, 6.5JJ, ET50, 60.1mm centre bore 1 Quote Share this post Link to post Share on other sites
RUToyota 102 Posted September 5 you could always use outfits like this to see what's available to you. https://www.wheelbasealloys.com/ Though if you are only looking for one spare then not so much use to you. Quote Share this post Link to post Share on other sites
