Technical:Touch2 and Touch2 and/with Go
flash22
On 5/17/2022 at 9:06 PM, flash22 said:
i took that down as it was incorrect, you may like to update your profile
its 2016 isn't it ?? i will drop you a PM
Thanks again Bob.
Could I trouble you to take a look at this, as the wiring colours from Russia/China don't seem to line up with the wiring diagram.
From the diagram, I think yellow (1) should be chassis ground, pink (2) is the VSS, red (3) is switched live and black (4) is permanent live.
I essentially want to splice the switched live to power a relay to shut off permanent live to the nav unit when the car is off.
Go by pin number, not colour
V4 in the PDF is the socket view
as you look at your picture
4 3 2 1
8 7 6 5
pin 3 is Acc
pin 4 is perm 12v
You can verify that with a multimeter
switch live and ground for the coil. Permanent live on in/out to the the load side
it's more than likely android getting corrupted as it powers on/off and/or It's got an update it doesn't like, if the module runs off a sd/tf card back it up and change the card to something name brand
