Power steering lumpy....
Snags
Hi, my vehicle is a Toyota Rav4, Diesel, LWB, 2002, 135k on the clock
I have what I can only describe as lumpy power steering when setting off or turning the wheel all the way around. I have checked the steering fluid level and all seems ok so I presume no leaks but what else could it be ? and is it an easy fix or do I have to send the wife out to work again? 🙂 Thank you
Check whether it's still lumpy with the engine off.  If so, it could be a seized track rod end or similar.
