Sign in to follow this
100leelee
2008 head unit no aux input.. options
Hi
the head unit has no aux input..
can I swap with a later head unit ( circa 2009 ) that has an aux input then fit an aftermarket aux input lead?
are there any other options??
cheers
Share this post
Link to post
Hi
std head unit
no aux input functionality
Share this post
Link to post
Looking at photos of a head unit from a 2009 car, that has the Aux functionality, the connections at the rear look very similar, aerial connection aside.
Has anyone tried to swap from a later car to an earlier one??
would like to keep the genuine look if possible..
could also go the fm/Bluetooth route.. anyone tried this?
thanks
lee
Share this post
Link to post
My 06 Corolla has the standard model W58814, and one of the two Connects2 units did the job easily for cable 3.5mm connection. The only difference between the two types is one plug to go into the back, so you need to check re that. I went to a Bradford store that does such things, very helpful..
In Car Emporium
Idle Rd, Bradford BD2 4ND
01274 627097
https://g.co/kgs/mzz1gr
If the bluetooth idea is attractive,  I believe they also do a (more expensive,  natch!) version with such connectivity.
Share this post
Link to post
Hi
would prefer to simply swap my head unit with no AUX input, to the next level up unit that looks identical, but has the AUX input option that I can connect a AUX lead into..,
Share this post
Link to post
Loading...
