T-Sport to Compressor Conversion
Nemmfesta
Anyone done a compressor engine conversion into a standard T-Sport? If so what parts are needed from the compressor other than Engine and ECU?
Wiring loom is little different due to relay etc for supercharger clutch, unless you go with a fixed pulley.
Intake manifold,
Oil cooler as engine will run hot,
Bigger injectors,
Bracing and suspension if you want of course,
ECU for a Comp as MAP is different, probably also need 98+ Octane fuel.
Might be cheaper to get a Comp in the end.
Thanks for the reply, there is a comp in at work I was thinking of the conversion but the cons outweigh the pro's.
