Rav4 xt3 d-4d 2004 Alarm info please
penny_lee
I just got my Rav4 yesterday and I have no manuals at all for anything and I have no idea how to use/setup a spare key fob as my only fob given is like broken and taped up but I do have a spare un-cut key fob that looks the same in every detail but i have no idea how to set this 1 up or how the alarm works.  Any information would help please.  thank you xxxx
Hi Penny, welcome to TOC 🙂
You should be able to find manuals for your entertainment/satnav if fitted at https://www.toyota-tech.eu/Aim/Aim2.aspx?pubtype=AOM
Sorry, can't help with the rest myself but hopefully some that can will come along.
Thank you Heidfirst, I checked but nothing there for the security system and setting up key fobs. xxxx
Afaik there are no manuals for programming the keyfobs.  Toyota expect you to hand the problem to the dealer, but this is not necessary.  Independent car locksmiths can do the job, or you can DIY. You will find the information you need in the links provided here.
Thank you so much IanML,  I am about to call a few car dealer locksmiths for quotes as i already have been given a black spare key, just hope the only key they gave me lasts as its held together with tape!!! xxxxx
Once you have the spare key working you might want to consider buying a new Shell (usually plenty on eBay etc.) for the old & transferring the gubbins over to that. If you don't feel competent to do that then I am sure that your auto locksmith (btw certain Timpsons specialise in car keys) should be able to leaving you in the final position of having 2 working & structurally sound keys.
