Wing mirror glass
Whoey90
Hi. After having my wing mirror glass smashed off for me, I have acquired a replacement but could do with tips on how to fit it please. Not sure where the metal spring goes and hinged tab fits. Car is an 06 corolla 1.4 vvti. Many thanks for any help.
Hi, the metal spring should hook onto the inside of the frame to spring it back into place when dislodged. The back of the actual mirror should have a ring of clips on the back side, which snap into the mirror holder. If the frame is damaged you might be better off at a 'scrappie' and replace the whole assembly.
