replaced the egr
bonnie&rocco
hi, ive just replaced my egr valve with a new mapco egr and hoping that my dash lights would go off this isnt the case, will the ecu take some time to register the new part?
have you got something that can reset it (e.g. OBD cable & Techstream)?
I recently got myself one, I'm abit novice with it, I did do a check with the obd when I noticed the lights were still on, prior to that when I replaced the egr I checked with the obd reader which said egr fault, so I disconnected Battery for about 15 mins thinking that would reset the ecu, after connecting Battery I used the obd and no codes found, went for a drive and lights came back on, then before making this post I did erase codes with the obd, I haven't driven anywhere since.
Could it be that to erase code with obd maybe of more use than disconnecting Battery
