1.4 d4d Cranks but, no start
Ryan W
Hi Toyota experts. Hoping someone can help. I have a Urban Cruiser with the 1.4 diesel engine 90,000 miles.
It's a daily driver and has been trouble free for the past couple of years until the other evening.
I have now towed the car home as unable to start.
It just cranks with no hint of starting.
EML is not illuminated and no codes stored. Plenty of good new diesel, plenty of Battery to crank.
In my efforts I have removed and cleaned the egr valve, cleaned the MAF. Removed and cleaned the SCV. I've cracked off the injectors and can see fuel coming through
My gut feel is it's a sensor playing up but would appreciate any advice
Thanks in advance Ryan
Welcome to Toyota Owners Club.
Moved to the Urban Cruiser club.
Worth checking your clutch switch. If the switch is faulty or your clutch not pressed all the way down, the engine just crank and won't start as part of the safety feature.
I am not 100% saying this is your problem , but it's worth eliminating it.
Thanks for info. With ignition on the start button is orange, when i depress clutch it goes green and begins to crank. Is that what you meant ?
The fact that your when you pressed the clutch and the light goes green indicate the clutch switch is ok. So you can eliminate this.
See anyone else got anything else to suggest.?
