ligths wont go off
barneysarah
hi help please my 2003 landcruiser light on even when ignition is off
anyone have any ideas
I have disconnected the Battery for now
any ideas thanks
Sarah
First thing to check would be the light switch. Try to wiggle it around, see if it does something.
Have you checked the switch, if it's possible to open the casing without having to remove it from the car (which i presume would be demanding)?
Temporary alternative could be putting a manual switch  to cut the power to lights when you dont need the.
