Toyota Corolla 2.0 d4d Sr gearbox whine
Mikepearce29
I've recently purchased a Toyota Corolla sr on 125,000 miles and I notice a slight whine in 3rd gear along with the typical clutch pedel squeek I've never owned or driven a diesel so just wanted to know peoples opinion on a Corolla whine
The clutch squeak is often caused by the plunger going into the clutch master cylinder and some careful lubrication usually cures that,  just do a quick search on this forum for  many similar posts .   It could also be, though less likely,  the slave cylinder contact point with the clutch pivot arm or in the whole clutch assembly , but try the foot pedal and plunger under the dash first, and give it a days use to  let the lubrication work in.
3rd gear whine apart from changing the transmission oil , cannot say, not a problem I have had, oil type usually 75W/90 GL4  1.9 ltr on the petrol version , use Commas myself.
