Toyota Auris 2011 fault
RhianJ
Hi. I have a 2011 1.3 Auris, which has developed a problem. it starts OK, runs Ok but when the enginr is switched off, the dash lights up with every symbols and says engine check and air bag check. Had a local garage to run transmision, which says its coming up with a lot of things.  I have just ordered a new Battery.  Please can I have advice or has anyone experienced the same problem
Welcome to Toyota Owners Club.
Moved to the Auris club.
Don't see how the transmission is related...
It would be nice if you could share some of those codes from the garage.
Isn't this the infamous 'Eco run converter module' fault. There have been a few posts about this over the last few years, unfortunately the forums search facility doesn't turn them up for me.
https://www.toyotaownersclub.com/forums/topic/189616-dash-remains-illuminated-after-ignition-off-check-engine-warning/
Many thanks Mooly.  That was exactly the problem.  Went to the garage last night who confirmed that I was correct; part was ordered and changed this evening.  No more Dash lights with key out of ignition.  Thank you very much for your help in sorting the fault - saves time and money.
Glad to hear car is sortes and you back on the road.
Sent from my SM-A307FN using Tapatalk
