Engine oil from breather hose
peter.ling24@gmail.com
Have a 2005 Avensis T Spirit 2.2 D4D. 79,800 miles.
Have noticed over several months that oil has pooled in the large aluminium pipe attached to the turbo, the other end attached to the air filter box.
The EGR valve has been cleaned, very little sooty deposit in it. In the cold weather it can be troublesome to start but after 2-3 attempted starts, it fires up. This only happens on the first start, the rest of the day it starts fine with no difficulty.
Could it be the Pressure Control Valve fitted to the end of the engine?
The car has always been regularly serviced.
I would appreciate any opinions please.
Peter
