Navigation system 2013 Yaris
Ray Bush
I'm thinking of adding the Navi unit to the head unit on my 2013 Yaris .I can obtain the Navi unit with fixing brackets and fixing bolts ,the two pieces of wiring loom that are plugged into the rear of both head and navi unit .As its new to me i'm not sure if there are any other leads ,i.e . a GPS lead and any that I would need that are not already on the car. I don't know what sort of job it is to remove the head unit and install the Navi unit and its wiring  . With most Navi units you need a SD card in conjunction with the kit ,is that the same for the Yaris system ,or is there another means .
Sorry its a bit vague ,but i'm trying to piece this together before I buy it and then try and install it.
Quote
I'm told that the car the unit was removed from is the same year as my car 2013.
