towbar avensis t27 year 2010
mekanieker
I have mounted a towbar myself, now only the electrical connection.
I have already purchased a 7-pin plug and a universal module.
does anyone have the colors of the wires of all the rear lights,
and also where I can best take off the 12 volts for the power supply for  the module.
  • 5 weeks later...
Hi Luc did you mannage to get the electrical connection sorted?
I have also mounted the towbar and also in doubt about what it is, the electrical installation manual exactly want me to connect.
The electrical installation manual states something about pin 11(signal RR fog) near the clutch pedal, but i'm very much in doubt what they mean?
Best regards
I have bought a DC Current clamp with this you can easily identify the correct wires
all the connections you need are in the cable harness in the trunk, and to amplify the signals I have bought
module
Logicon Towing Interface zr2500
onley extra you must do is ,pull a thick elektrical wire from the Battery to the trunk for feeding this module
