squeaky clutch
mekanieker
squeaky clutch
it only beeps if you operate it
can you lubricate this without disassembling the gearbox?
greetings from belgium
(auris 1,4  year 2007)
Usually the squeal is caused by the slave cylinder piston operating the clutch fork.
You can try to dab some grease on the contact point between the slave cylinder piston ring and the fork.
Don't be tempted to spray anything, this is not a permanent fix, sound usually comes back after couple of months.
i have grease the slave cilinder ,but no luck,
is difficult to detect the sound from where it comes
 can i also lubricate the master cylinder, but how
i feel litle vibrations when i operate the clutch by hand
There is no need to grease the master cylinder.
The squeak you have is either on the clutch fork and master cylinder, or the clutch fork and the release bearing inside the clutch housing.
As for operating the clutch by hand, it's a moving part, things vibrate whey they move, you're just overthinking it.
I had clutch squeal also, it's not that uncommon, if that is what worries you.
Anyway it should not have any impact on the way the clutch operates.
