Rear Fog Light Switch HELP
Astbury67
I need to get a Rear Fog Light Switch for my 1999 Corolla but can't find one.
Does anyone know if one from another Toyota would fit, i've seen the MR2 mk2 has 8 wires but not with the same colours, or could i wire on another
next to it just using the wires for the fog light as i would need to keep the old one for the main lights.
This seems to be very hard to find as i have been looking for over a week.
Moved to the Corolla club.
Assume you have tried Mr T spares dept - no longer stocked ?
One of the online scrapyard may find one for you ?
As you have a blanking plate, you could drill it to take one of these small rocker or toggle switches instead, as here or eBay etc,  -
https://www.switchelectronics.co.uk/switches
Don't know if yours is like mine, but the factory fog light was just on the offside light clutster only, no bulb or wire in the nearside, though the bulb holder is there, so popped in a bulb and wired across so both now light up.
Having been stuck in some of your Scottish coastal fogs, think you really do need both lights on !!
