Rear washer
peter.ling24@gmail.com
Hi all,
2005 2.2D.
My rear washer has stopped working. The front washers are fine. Are there 2 motors? One for front and one for rear. Can anyone help please?
Regards
Peter
Almost certainly two motors as they run separately, and it would be easier than switching valves. Do you hear the motor running when you activate the rear wash?
Hi Paul,
Just been out to the car. Cannot hear motor running when rear washer switched on.
I guess it's the motor? The 20 amp fuse is ok.
Appreciate your helpful advice.
Peter
Does anyone please happen to have a diagrammatic of where the rear washer motor is situated and how you can get to it.
Peter
Two pumps in the front washer bottle under the wing liner :thumbsup:
Thanks Kingo.
I have found a front motor washer for sale. Are the motors interchangeable please? Front for rear and visa versa?
Appreciate your reply.
Peter
Edited by peter.ling24@gmail.com
Add extra information
If you have a multimeter and an idea of what you are doing, then it would be a good thing to check the switch and any related relay before you fire the parts cannon at what is still quite likely to be a bad motor. You could also try swapping the front and rear motor on the washer tank too see if the fault moves,  if they are both the same. The Toyota Tech website or something similar is quite likely to have a parts list which you could use to see if the motors are the same, if you can't easily get to them.
Hi Paul,
Very good suggestions Paul,  particularly seeing if the motors have the same part number.
I'll do this.
Thanks Paul.
Peter.
