Bluetooth tethering android
Cbatoday
Is there an app to use to keep bluetooth tethering on automatically after a reboot or when you have switched to airplane mode
Find it a bit annoying as it doesnt always connect to the car because of this
I use Blue Car Tethering on Demand available on the Playstore.
I use Macro Droid. You can create a rule that initiates bluetooth tethering when the car connects.
Tried blue car tethering but wasn't compatible with android 10 yet.
Used macrodroid and works a treat. Updated to premium for the £3
Was using tasker but that was not as user friendly.
Thanks for the tip
I'm using the blue car tethering app and i'm on Android 10 however i had it installed before upgrading so i'm sure if my phone is reset/replaced for some reason then i'll have to come back here and use that macrodroid app!
