aladinsain 1 Posted January 28, 2020 Share Posted January 28, 2020 Hi i have shorted the wires on my Avensis mark 3 2009 main power window switch now i have no ignition check all fuses in engine compartment all seem to be ok checked fuses 1-15 under passenger glove box going to check 16-31 tomorrow have headlight and interior lights working cannot lock doors and no ignition i wondered if there was anywhere else to check ? Quote Link to post Share on other sites
furtula 290 Posted January 28, 2020 Share Posted January 28, 2020 We need to how exactly you shorted the wires, was the car running, what happened after if it was running? Quote Link to post Share on other sites
aladinsain 1 Posted January 28, 2020 Author Share Posted January 28, 2020 no it was not running but i believe that there is a constant live wire in there Quote Link to post Share on other sites
aladinsain 1 Posted January 28, 2020 Author Share Posted January 28, 2020 and i think the red wire and the black/white wire touched Quote Link to post Share on other sites
Konrad C 955 Posted February 4, 2020 Share Posted February 4, 2020 I only just found this by accident. Should be in the Avensis forum. If your car is a T27 Mk3 Avensis, then you need to also check the under dash fuse box located in the passenger footwell ,beyond the glovebox. Your owners handbook has this information. From there you can check the fuses, like fuse 13. Quote Link to post Share on other sites
aladinsain 1 Posted February 17, 2020 Author Share Posted February 17, 2020 thank for your help have sorted it it was the ignition 10 amp fuse in the engine bay which look ok but i changed it and that was the fault 1 Quote Link to post Share on other sites
