Will not start after a timing belt change
Shanecane
Hi all
i have changed my timing belt and now it cranks over but will not start
the timing marks all line up we have fuel and spark but I don’t know what to do next can anyone help
I'd go back and double/triple check your timing marks are good.....did you try to start the engine using the starter motor after the belt change.?
Hi mate
I rotated the engine with the pulley first all was correct then I reassembled and tried to start but no success, I have sine pulled of the inspection covers and the harmonic balancer and rechecked it all again all of the marks line up
also the timing mark is at 10 degrees when the no.1 cylinder is at tdc
what engine and year ? did you lock the pulleys ? all the electrical connectors in place ? any eml light/codes ?
The crank pull should line up with the 0 (assuming it has the 4 marks)
