Changed battery, car wont start.
Bryan CH
Hi, as the title says I changed a low Battery for a fully charged one, (newish), and when re-connected the indicators stayed on, (no flashing), and the engine will turn over but not catch. It seems to have "locked" me out. Any idea where the "reset" button is?
TIA
Bryan
Sorry, car Battery. Ones' mind get fixed into something and you presume other people are thinking the same. Doh! <smacks head>
3 minutes ago, flash22 said:
Is it the battery the same type with the positive in the same place ??
Car Battery, yes Bob. Just a slightly higher a.p.h.
i would check the polarity to make sure, do the dash lights come on ?
did you just undo the terminal or the nut on top as well ?
Polarity's ok and I can't remember if the dash light comes on - must do if the engine turns over though, eh?
undo terminals, nut on top?
I maybe thinking of later cars
usually there if a nut/bolt on top of the terminal that connects the wiring
Thanks, I'll check that tomorrow. ref: the "Uncle Bob" thing; almost brand new Battery, (3 months).
