Zekedog21 0 Posted February 9, 2020 Share Posted February 9, 2020 Car won't start ,screen says p lock problem, showing about 9 amp draw with power button pushed, won't go to ready mode all warning lights on and triangle Quote Link to post Share on other sites
FROSTYBALLS 3,423 Posted February 9, 2020 Share Posted February 9, 2020 Probably be helpful to know what year the Prius is. Quote Link to post Share on other sites
Zekedog21 0 Posted February 10, 2020 Author Share Posted February 10, 2020 Gen 2 2007, 146 k miles Quote Link to post Share on other sites
flash22 655 Posted February 10, 2020 Share Posted February 10, 2020 Have you had the codes read ? p Lock is usually a flat aux Battery - replace the Battery with same type only (AGM) You can check the 12v Battery voltage by putting the mfd into maintenance mode There is a work around by pulling a 7.5a fuse have a look on youtube 1 Quote Link to post Share on other sites
Zekedog21 0 Posted February 11, 2020 Author Share Posted February 11, 2020 Battery is good,, tryed the 7.5 fuse work around no codes Quote Link to post Share on other sites
Joseph D 123 Posted February 12, 2020 Share Posted February 12, 2020 On 2/10/2020 at 9:14 AM, Zekedog21 said: all warning lights on and triangle 9 hours ago, Zekedog21 said: no codes If you have lights, you have codes to be read. With what are you reading the codes? Sounds like whatever you are using can only read basic ECU and maybe ABS. There are about another 9 ECUs you are not seeing. Quote Link to post Share on other sites
Zekedog21 0 Posted February 12, 2020 Author Share Posted February 12, 2020 8 hours ago, Joseph D said: If you have lights, you have codes to be read. With what are you reading the codes? Sounds like whatever you are using can only read basic ECU and maybe ABS. There are about another 9 ECUs you are not seeing. Used snap on ultra scanner poa63. 72,, 75,,,78,,, 7a,,, ef ,,,p3222. Seemed to have some bad grounds which I fixed. Don't know think inverter pump was running but it is now Quote Link to post Share on other sites
Joseph D 123 Posted February 13, 2020 Share Posted February 13, 2020 21 hours ago, Zekedog21 said: poa63. 72,, 75,,,78,,, 7a,,, ef ,,,p3222. All these codes point to issues with your transaxle and possibly the inverter. You need to look them up in the repair manual as they are quite involved in diagnosing. Quote Link to post Share on other sites
flash22 655 Posted February 13, 2020 Share Posted February 13, 2020 I would be checking that 12V Aux Battery properly under load with a Battery tester, electronics do strange things with low voltage/current, its more than likely the original so 13+ years old Remember these codes are a symptom, not the fault Quote Link to post Share on other sites
kithmo 268 Posted February 13, 2020 Share Posted February 13, 2020 First thing that came to my mind when you mentioned P-Lock is the parking pawl. Can you move the car when you take the manual (foot operated) parking brake off ? Quote Link to post Share on other sites
Zekedog21 0 Posted February 13, 2020 Author Share Posted February 13, 2020 1 hour ago, kithmo said: First thing that came to my mind when you mentioned P-Lock is the parking pawl. Can you move the car when you take the manual (foot operated) parking brake off ? Yes it goes to n and will move Quote Link to post Share on other sites
kithmo 268 Posted February 14, 2020 Share Posted February 14, 2020 16 hours ago, Zekedog21 said: Yes it goes to n and will move What I was wondering is if the pawl is not engaged when in "P" I meant can you move when it in "P" ? Quote Link to post Share on other sites
Zekedog21 0 Posted February 15, 2020 Author Share Posted February 15, 2020 11 hours ago, kithmo said: What I was wondering is if the pawl is not engaged when in "P" I meant can you move when it in "P" ? Sorry ,it will not move in p Quote Link to post Share on other sites
kithmo 268 Posted February 15, 2020 Share Posted February 15, 2020 ok, it's not the parking pawl then. Quote Link to post Share on other sites
