P lock
Zekedog21
Car won't start ,screen says p lock problem, showing about 9 amp draw with power button pushed, won't go to ready mode all warning lights on and triangle
Probably be helpful to know what year the Prius is.
Have you had the codes read ? p Lock is usually a flat aux Battery - replace the Battery with same type only (AGM)
You can check the 12v Battery voltage by putting the mfd into maintenance mode
There is a work around by pulling a 7.5a fuse have a look on youtube
9 hours ago, Zekedog21 said:
no codes
If you have lights, you have codes to be read.  With what are you reading the codes?  Sounds like whatever you are using can only read basic ECU and maybe ABS.  There are about another 9 ECUs you are not seeing.
Used snap on ultra scanner poa63. 72,, 75,,,78,,, 7a,,, ef ,,,p3222.  Seemed to have some bad grounds which I fixed. Don't know think inverter pump was running but it is now
All these codes point to issues with your transaxle and possibly the inverter.
You need to look them up in the repair manual as they are quite involved in diagnosing.
I would be checking that 12V Aux Battery properly under load with a Battery tester, electronics do strange things with low voltage/current, its more than likely the original so 13+ years old
Remember these codes are a symptom, not the fault
First thing that came to my mind when you mentioned P-Lock is the parking pawl. Can you move the car when you take the manual (foot operated) parking brake off ?
Yes it goes to n and will move
What I was wondering is if the pawl is not engaged when in "P" I meant can you move when it in "P" ?
Sorry ,it will not move in p
