Find Me A Yaris Hybrid! (Sequel to Find Me An Auris Hybrid!)
Wayne2015
You CRACK me up :laughing:
(o)hmmmmm(let).... 🤔
New subject please as this thread is getting eggcruciating
  • Haha 1
Well, put the spare alloy in boot well and...
The locking thread 'just' touches the thread hole...so need a thread extender as Flash22 says...
Wait...
Does the alloy (or thread hole) look off-centre to you? 🤔
If I put the full size wheel in (tyre + alloy) would the thread hole be NOT align with centre hole of alloy???? :jawdrop:
  • 4 weeks later...
Well, hope everyone is well and safe 🙏
Thanks to Flash22 suggestion:
Just a case of buying a new full size tyre now :driving:
On 9/2/2020 at 6:57 PM, flash22 said:
dont forget the tyre will raise the alloy a tad
Yeah, it's impossible for me to find a perfect bolt extender - coz as you said the alloy is raised higher, but the spare wheel clamp bolt JUST touches the bolt hole - so no room for a perfect bolt extender.
I have bought a brand new tyre now (Nexen with lifetime guarantee at £65)
Put new tyre in, insert clamp + bolt extender (about 2mm gap between clamp + alloy) : just squeeze a old t-shirt in and now it's a tight fit! :flex:
The boot is raised - so have some old computer foam packings (big poly rectangle pieces) - that just about the right height to raise rest of the boot floor to the new tyre height 🙂
Hi Wayne
Had your problem last night. One of my headlights was out.
Looks like my optiwhite bulbs are already had it. Luckily I kept the original ones and when I put one in and put the lights on. The remaining optiwhite was as dim as the standard one.
Now do I try to get the Toyota optiwhite or try another brand. ?
Sent from my iPhone using Tapatalk
30 minutes ago, flash22 said:
Amazon is £105, that is an enormous price to pay for 2x the brightness (upto 200% more mean 2x right?)
Even at 85 is a very big price tag.
1 hour ago, flash22 said:
i will stick with Osram or Phillips, hir2 bulbs are a bit of a pig to find tho
Fitting them is a right pain also
Had to replace mine already.
