Prius Key Fob
MichaelM
Not to be recommended but:
1 hour 40 minutes at 30 degrees with washing powder plus rinses and several spins at 1000rpm.
Then remove your Prius Key Fob from the washing machine, dismantle and remove the Battery.   Put above a radiator for 24 hours to dry.
Finally reassemble and if you are as fortunate as I have been, your key fob along with the keyless entry will still work perfectly.
I should mention that I do not make a habit of inadvertently putting my key fob in a washing machine !
  • Haha 1
