coolant light flashing intermittently
bikervirgin
Hi I Have a Toyota aygo 1.0 petrol and the coolant light flashes on then the stop light comes on, this then goes out, I stop and check the engine. it doesn't seem to be overheating and have checked the coolant reservoir which seems ok. I have also checked the oil and no gunge or smell of fuel in the oil.
Help please as cant seem to find a problem or any leaks, is it safe to carry on driving
In the back of my mind maybe thinking the water pump???
i'm thinking there maybe air in the system and this would explain why the stop light
comes on then goes off, when air moves past the temperature sensor the temperature
will go up then the following water will give a cooler reading.
