Toyota b9012 sat nav unit
atevagge1983
Hi . I have the toyota b9012. My question is : I want to see in the screen the fm stations of radio. I see them, but it turns on the gps map after 10 sec.
Is there a way to see only the stations of radio and don't change to the map of nav;
Something like pressing the INFO button, go on to the screen/display settings that come up in that menu and there should be a setting there to stop the map screen coming on automatically, going from a hazy memory.
I did all these but the map is on the screen after 10 sec.
If I push the info button and after push the fm button, after 10 sec the screen turn to the info menu.
No in radio menu. Please give me some advices....to solve this.
I send one photo of radio-nav
The menu you are looking for may be on the Setup button. I think the Audio button switches to the tuner view, if you can't find the setting to help you. My unit was a slightly older model a little different to that one.
In the setup button I don'tfind  something which show the fm stations for ever on the screen. And when I push the audio button it turn to the fm stations but only for 10sec. After it turns on the map or on the setup menu.
I hope if someone had this problem and solved it...
I found it . Setup...generals...change monitor....no auto
