Wiper delete
JMcGwyer
I was wondering if anyone has removed the rear wiper and motor off their aygo.  Could anyone advice me on any delete plugs or send pictures of their car without wipers to view
Just interested in getting an idea of how it looks and how easily done it is
Cheers
attached is a link showing of the rear wiper motor, it looks like there is only 2 mounting points
i.e. through glass and on the right of the motor
you may have to glue the wiper motor cover back so it covers the wiring
as i think it clips onto the motor assembly
the other important part to find is a grommet to seal the hole in the glass
and then test it for water tightness ,you really dont want to introduce a water leak in an aygo
they come with enough entry points from the factory.
https://www.ebay.co.uk/itm/Wiper-Motor-VALEO-579712/153647586738?fits=Model%3AAygo&hash=item23c61c1db2:g:CjwAAOSwBOpdgjDH
You can't see who is behind you 😐
The Aygo tailgate is all glass the motor is just held by the spindle with rubber mounts against the glass and one bolt into  the handle bracket
32mm rings a bell
