Signal indicators and hazard lights not working.
Mr Doong
Hello members
My wife's 2013 Aygo signal lights and hazard have stopped working. The signal lights do come on if only you push it half way. The hazard light are not working at all.
At first, I thought it was just a replacement bulb or broken fuse, but its still not working.
I searched on this forum and some people are saying it is a switch. What switch are you referring to and where is it located?
Any ideas?
the indicator stalk / switch around the side of the steering column
wiggle the hazard switch, psa cars suffer with bad switch gear, I have done a few saxo, clio and other cars that share the same switches
apart from that check the fuses and relay
Thankyou for your answers 🙂
Is there any diy links on how to change the switch around the around the steering column?
if my old memory serves me correctly
i am sure there has been a post with someone taking apart
the indicator switch to clean the contacts and tweak them slightly
and this worked well.
thanks mate for your help. I found a few YT videos to guide me.
Does the indicator switch stalk somehow effects the hazard lights as my one isn't working at all?
It all runs through the gauges, i would suggest you disconnect the Battery for 10-15 mins and let things reset
Related fuses are
ecu-b No.1 7.5A (under bonnet)
Meter 5A
Haz 10A (under bonnet)
A blown bulb (dead short) may have popped a fuse or confused the dash (gauges) so pull the bulbs and check them
https://cardiagn.com/toyota-aygo-em3125e-electrical-wiring-diagrams/
