Corolla Verso 2005 2.0 D4D - Black goo around fuel injectors
ReEbel
image.thumb.png.95c92c8f76d8c5c2e7b44a440686a7d3.png20200327_224246.thumb.jpg.c755e7805a6adf05bb5b495cb2556763.jpg
Last month my alternator died suddenly and after doing quick check I realized that  there is black goo all around injectors fuel lines and down to alternator I managed to buy Nozzle Holders but there is  no way to buy new pipes. My plan is to clean cover, replace rocker cover gasket and clean the pipes.
Is this common problem with injector pipes in D4D? Does anybody now any solution for this leakage ? Is it just diesel leaking or the engine oil too ? What is the correct torque for those injector pipes ?
Thank you in advance for a help.
  • 2 years later...
Hello, Did you have any luck with this? As I'm having to deal with one of many oil leaks on my wifes Verso, this is one of them. Ive got the gaskets.
Many Thanks
