2006 Corolla windows stopped working, except driver`s window.
mart rotherham
I am unsure why both the rear windows and the front passenger side window have stopped working. The driver’s window  works fine. My first thoughts are that the 3 windows are maybe on the same fuse, and the driver’s window on a separate fuse?
There  are two  fuse boxes on the car-one under the bonnet, and one sort of under the dash above the foot-well. That is quite a lot of fuses to check through. Does anyone which box contains the fuse for the windows is located and what rating it is? I suppose being the estate won’t make any difference? I am assuming it is only the use.:dontgetit:
 Thanks.
Have you accidentally pressed the window isolation switch on the driver's door switch panel - which stops the non-driver's windows operating??
Hi Frosty, I didn't know about that switch. Is it located by the other switches on drivers door panel?
I think Frosty is talking about this one :-
Yes - as I said it is on the driver's door switch panel as above. Common error to depress the switch without noticing.
Thank you guys, that was the problem. I am pleased you posted before I spent ages going though the  fuses.
Thanks you, much appreciated.
