Vvti cam problem
frankie406
13 Nm for camshaft bearing cap bolts and 23 Nm for camshaft front bearing cap bolts.
I hope you know tightening sequence of bolts.
Good luck !
Any info would be greatly appreciated,  i will also have a mechanic seeing me through it too.(hopefully) thanks again.
Scrapping the car, its not worth fixing it then selling it on,just costing too much. Sad to see it go, only had 65000 miles on it for a 10 year old car. Picking up a Vauxhall mokka ( i know dont judge me) on Friday . So thanks to all you guys for your help and replies in both the avensis and auris forums! It was greatly appreciated. 😞😪
