Wiring double din radio
Nollie17
Hey all I’m new to wiring radios.(never done one in my life haha) my new radios just arrived it’s this one :https://www.amazon.co.uk/gp/aw/d/B07N7PVS4Q/ref=ya_aw_od_pi?ie=UTF8&psc=1
I have an 07 toyota aygo and I have a few questions would be majorly appreciated if someone could help.
1.Do I need to buy a radio harness adaptor for the wiring on this new stereo?
2.If I don’t need a new harness how do I go about wiring the radio
I think besides wiring I have everything I have a fascia and the kit for fitting it an aerial adaptor the stereo and the connections for the new radio that came with it just lost as to where to start with wiring
ive attached pics of the connections on the new stereo
Also if I do need a wiring harness could anyone send me a link to one for an aygo as I haven’t been able to find one!
Hi there,
I am sure others will come along to help you out here, there are some very knowledgeable people on this forum
We replaced our stock radio for a new Sony last year, definitely used a harness which was a perfect fit, and the job was straight forward, I'm sure there are loads of videos on YouTube to help you at every step
10 minutes ago, SAM LOVERS HER TOYOTAS said:
Hi there,
Do you know where you got the harness from?
You can get a harness adapter for the car made by connects 2 (no steering wheel controls)
if you have steering wheel controls you will need an adapter for them, but you may have issues with these cheap Chinese units get it to work properly
You will also need an aerial adapter and a maybe a fascia adapter
Are you really putting this in a brand-new car ? also with the double din in the Aygo the radio can be no deeper than 150mm
please update your profile
The full kit for the Aygo is CTKTY17
https://connects2.com/Product/ProductItem/CTKTY17
https://www.ebay.ie/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=CTKTY17&_sacat=0
Do I need a harness adaptor? There is no steering wheel controls for the radio
i know I’m a rookie but honestly lost with where to start with wiring as any videos of seen for an aygo they don’t show the actual wiring literally just show the wiring done and then put the radio into the fascia
I’ve been looking at radio harnesses for a Yaris which look exactly the same would this be correct? Would a Yaris radio harness work with my aygos radio setup
Sincere apologies, on second thoughts, I don’t think that we did use an adaptor, once we removed the old stock radio including the wiring plugged in, we were left with the existing wiring rooms coming from the car which were female, and the wiring from our new Sony were male ends and plugged straight in...i Remember it now, it was so easy.
My original links where for the 2014-2020 aygo
you will need a fascia as it's a 2007 -
CT23TY23 https://www.ebay.co.uk/itm/Connects2-CT23TY23-Double-DIN-Facia-Plate-for-Toyota-Aygo-2005-2014/352510161142?hash=item52133e30f6:g:xnkAAOSwfX9b5Aw6
also a
ISO to DIN aerial adapter https://www.ebay.co.uk/itm/Connects2-CT27AA01-Aerial-Antenna-ISO-to-DIN-Adaptor/171375678535?hash=item27e6c95447:g:ZDgAAOSwy3Jb3XV1
The radio you have has iso on the rear so just a case of plugging it in
