2002 PRADO 120 ECU
ZEB75
HI all, this is my first post and i am looking for some help please.
My dad got a prado which is registered overseas and the ECU needs replacing
PRADO 2002 SEPTEMBER J120
3.4L PETROL AUTOMATIC
VIN-VZJ1210001691
ENGINE 5VZFE
MODEL CODE - VZJ121W-GKPGK
i cant seem to find it online, could someone kindly suggest websites or shops i can try and get it, i can buy from the USA, UK, AUSTRALIA, NEW ZEALAND, SOUTH AFRICA
i am based in the UK and he car is in AFRICA
THANKS
Ecu's rarely need replacing - poor diagnostics - unless it has been proven there is an actual fault with it
What codes or issues does it have ? Has the Ecu had an update done ?
A new ecu will need programming to the car your best off getting the part numbers off the ecu - according to the epc it should be 89661-6A170
It was a JDM Spec car
thanks for those replies, the car had been checked by a toyota dealer, let me chase up the report from them, but the main issue was fuel consumption had gone up averaging abt 100km/full tank and u could smell the rich fuel exhausts. have also noticed that te same engine was used on the GRANVIA,  TUNDRA AND TOCUMA.
someone had also suggested that if we get a new ecu it will need programming together with the key, key reader and immobliser
thanks again for the replies
My auntie had this problem with the rav 4, ended up being injector's
Sent from my Pixel 2 XL using Tapatalk
i would check the injectors with a multimeter for resistance if one did go bad it may have fried the injector drivers in the ecu but that is very slim
a bad coil or spark plug could cause the same symptoms - do you know if there are any misfire codes if so look at the misfire monitors to determine what cylinder it is
