Tom Bu 0 Posted April 27, 2020 Share Posted April 27, 2020 Hi All, New to the forum, so please go easy on me! I am trying to find out if it is possible to retrofit Cruise Control to my version of the Yaris. From the VIN number I have come to the conclusion that the specific model number is NSP130R-CHFGKW. I have heard various ideas as to whether it is possible or not, including US vs EU spec Yaris', Petrol vs Diesel, 1.0 vs 1.3. Basically, I would hope to find someone who could tell me if Retrofitting Cruise is possible on THIS Yaris spec, and if so, which stalk to buy (on ebay etc). I have retrofitted previously on VW motors so skill isn't a problem here, just technical information. The steering wheel is the multi function version with media and phone control. There is a small bit of trim on the right hand side which pops off and reveals (what to me looks like) the mounting for a Cruise Control Stalk. I know there are other forum posts out there regarding Cruise Control however non of them seem to answer my question. The car in question is: Yaris 2012 NSP130R-CHFGKW EU spec built in France Engine: (1NRFE) 1300CC 16-VALVE DOHC EFI 6 speed manual gearbox Right hand drive Thanks for your help!!! Quote Link to post Share on other sites
flash22 659 Posted April 27, 2020 Share Posted April 27, 2020 Its only the 1 litre that don't have the programming, there are lots of threads and videos on YouTube Add the stalk - you may have to add a wire to the ecu from the connector behind the dash on the passenger side if it's not fitted - being a manual you may need to add/change the clutch switch You will not know until you take things apart tbh get a genuine stalk and not a cheap knock off Stalk part number is - 84633-05010 If it doesn't come with the wiring that is. 84632-0F010 going off the Model number given Quote Link to post Share on other sites
Tom Bu 0 Posted April 27, 2020 Author Share Posted April 27, 2020 Thank you flash22 for your very prompt and useful comments. It's great to get some clarity on the matter. With part numbers as well! Thank you very much, I really appreciate it. Quote Link to post Share on other sites
Tom Bu 0 Posted May 4, 2020 Author Share Posted May 4, 2020 Having purchased a stalk and cable kit (part number 84632), I can now confirm what Bob @flash22 mentioned earlier. My Toyota Yaris now has Cruise Control!!! It took all of 30min, most of which was figuring out how to take off the Airbag. Thanks Bob for your help on this. One last question if someone feels like answering: To install the new cruise control stalk I had to remove a trim cover (part no. 3071990). Does someone have a part number for a direct replacement Dust cover for the new stalk? Please? Thanks Quote Link to post Share on other sites
stevecrvn 27 Posted May 4, 2020 Share Posted May 4, 2020 Hi All Will this work on a 2015 hybrid ICON ? Quote Link to post Share on other sites
Devon Aygo 963 Posted May 4, 2020 Share Posted May 4, 2020 1 hour ago, Tom Bu said: Having purchased a stalk and cable kit (part number 84632), I can now confirm what Bob @flash22 mentioned earlier. My Toyota Yaris now has Cruise Control!!! It took all of 30min, most of which was figuring out how to take off the Airbag. Thanks Bob for your help on this. One last question if someone feels like answering: To install the new cruise control stalk I had to remove a trim cover (part no. 3071990). Does someone have a part number for a direct replacement Dust cover for the new stalk? Please? Thanks Part number for trim with Cruise control 45186-0D030-C0 Quote Link to post Share on other sites
flash22 659 Posted May 4, 2020 Share Posted May 4, 2020 2 hours ago, stevecrvn said: Hi All Will this work on a 2015 hybrid ICON ? It should do 1 Quote Link to post Share on other sites
HughA 12 Posted May 4, 2020 Share Posted May 4, 2020 Surely a 2015 Hybrid Icon has cruise control factory fitted? Mine has! Quote Link to post Share on other sites
stevecrvn 27 Posted May 4, 2020 Share Posted May 4, 2020 Just now, HughA said: Surely a 2015 Hybrid Icon has cruise control factory fitted? Mine has! No not fitted to mine for some reason Quote Link to post Share on other sites
flash22 659 Posted May 4, 2020 Share Posted May 4, 2020 Not as standard, it was an option on the icon iirc the icon tech,Y20 and excel have it as standard The 1.0 mk3 didn't even get it as an option but there was one oddball spec that did 1 Quote Link to post Share on other sites
Ebrahim23 1 Posted February 19 Share Posted February 19 Hi i have a yaris 2013 1.3 XS model , I bought a cruise control stalk and fitted it on my vehicle but it does not work, any ideas? Here’s a pic of the unit i bought, it’s from a 2009 Toyota Rav 4 , it has the code 18A174 on it. Could my vehicle possibly be not wired up for cruise control? There is the cruise control lights in the back of the cluster but they don’t light up even when the vehicle is in the ON position and all the other lights come on. Quote Link to post Share on other sites
Ebrahim23 1 Posted February 19 Share Posted February 19 29 minutes ago, Ebrahim23 said: Hi i have a yaris 2013 1.3 XS model , I bought a cruise control stalk and fitted it on my vehicle but it does not work, any ideas? Here’s a pic of the unit i bought, it’s from a 2009 Toyota Rav 4 , it has the code 18A174 on it. Could my vehicle possibly be not wired up for cruise control? There is the cruise control lights in the back of the cluster but they don’t light up even when the vehicle is in the ON position and all the other lights come on. my car is a manual as well, maybe the clutch switch is needed to activate the cruise control? Quote Link to post Share on other sites
flash22 659 Posted February 19 Share Posted February 19 It really depends on the car it seems after a few owners have tried to fit CC even tho it's all physically installed it not programmed in to the ecu there are a few threads on the subject inc a recent one Quote Link to post Share on other sites
Ebrahim23 1 Posted February 24 Share Posted February 24 @flash22i have the same model yaris built in the same place and the same year as well, i installed my stalk and it does not work, any ideas? Quote Link to post Share on other sites
flash22 659 Posted Thursday at 10:24 AM Share Posted Thursday at 10:24 AM i did reply to your topic, please keep it to one thread it's easier to keep track of Please PM me your VIN Quote Link to post Share on other sites
yusrayetu 0 Posted Monday at 03:40 PM Share Posted Monday at 03:40 PM I have recently received important recall information regarding Toyota Yaris hybrid front driver airbag inflator from Toyota. I booked appointment on 6th March. My Toyota Yaris Hybrid 2015 is not currently fitted with cruise control. I would like to ask you if Toyota dealers are able to accept fitting this part while replacing front driver airbag. I'll pay addition cost for the cruise control. Has anyone done this service before with Toyota?. Many thanks Quote Link to post Share on other sites
FROSTYBALLS 3,430 Posted Monday at 05:11 PM Share Posted Monday at 05:11 PM Topics merged. Quote Link to post Share on other sites
flash22 659 Posted Monday at 06:01 PM Share Posted Monday at 06:01 PM The dealer is not going to be interested/will tell you it's not possible plus the stalk is likely to be £90 inc the screws and cover PS. Don't be surprised if they cancel the airbag appointment due to parts supply issues Quote Link to post Share on other sites
