Buying advice - what to watch out for
m4rkw
I'm going to view a 2008 rav-4 tomorrow from a private seller. It looks to have been well maintained but other than the obvious HPI check, V5 present, oil level and does everything work etc is there anything rav-specific I should look out for? Luckily with SUVs there's space to get under them and check for any major rust which makes buying a lot easier for the average person!
Any tips most appreciated.
Diesel or petrol?
If diesel, some with the AD series engine could suffer from head gasket failure. This was covered under a goodwill arrangement  for a period of 7 years/111,846 miles from first registration, whichever came first - although all affected Rav's are now well outside this help. Toyota's solution was a revised 3/4 engine. The same engines were used in the Auris and Avensis. A Toyota dealer should be able to confirm whether a Rav has had a rebuilt engine.
Some have since tried head gasket repairs, but few came back to say how successful this type of repair was.
See
It's a petrol so thankfully don't need to worry about that! Thanks though. It's also a manual so don't need to worry about transmission fluid changes.
Don't forget stay alert, stay safe, save lives. Observe social distance.
Fuel filler pipes prone to leaking due to rust,ask if it's been replaced.
