I have just downloaded and installed the 2020/1 map update via USB and here are a few observations which may help others.
1) You will need at least a 16 GByte usb stick, preferably USB3 for speed, the file size is 11.9 Gbytes.
2) If your computer is like mineĀ (Windows 10 64bit ) don't try to unzip by directly copying the FMU folder straight to USB. This was desperately slow and would have taken hours. Instead unzip to your local hard drive ( 2 minutes ) then copy the FMU folder to your
