Starlet Horn Issue
RenBlu
Hi guys, having an issue with the horn on my Starlet P7. The horn is working when hooked to the Battery so I tested the connector for the horn.If I connect the green/white wire and earth it off the body it works but stays on. So leads me to a wiring problem, Green/white wire which goes to the fuse box has power but the green/red wire which goes into the car also has power going to it. I thought the green/red would be a negative?. I have an aftermarket wheel and boss kit so I fitted the original wheel and it was still the same. Thinking it's a short in that wire ?
Any help would be greatly appreciated
Sometimes components are permanently supplied with +12v and the switch (or horn button in your case) adds negative.  Check your wiring again with the horn button pressed.
Have you checked the fuse or had a look at the relay ?
