Dashboard warning light
Swerve74
Toyota auris hybrid flat Battery. Once I got the car charged and running there was a light on the dashboard that won't go off. Traction control. If I enter maintenance mode will the correct the light or does it need reset diagnostically. Thanks.
Hi Have you tried stopping and starting the car a few times it cleared the 5 faults I had when my Battery went flat on my Prius.
Moved to the Auris club.
