2011 Auris USB/AUX not working - cable required
Varunan
Hi
Where can i buy the cable to connect USB/AUX adaptor and the audio system.?
I recently bought used 2011 Auris TR. It has USB/AUX adapter in the Auxiliary box. But, audio system did not recognise USB or AUX. When I removed the adaptor, I found that it is not connected to the audio system. there is no cable either. Where can i buy this cable? I tried to search but couldnt find any matching cable. Photo of rear side of USB/AU adaptor attached.
Please help.
thanks,
Varunan
Is it a factory radio or an aftermarket one, do you know the model or can you post a pic ?
As for that port pictured a standard usb cable plugs into the usb and the 5 pins are for the aux in - it may have had/still has an aftermarket stereo and was not wired up
Thank you.
This is a factory radio. number says 13838. I will take a picture add here.
Also, when you say 'standard USB cable' are you saying the usual USB cable available in any shop? If yes, I tried that, it doesnt fit in. If not, possible to help me with a pic from internet?
I think Varunan is referring to the cable in this picture. The USB/AUX thing in my 2010 Auris HSD wasn't working and I found out the connector wasn't plugged in!
Unfortunately I couldn't find any serial number on the cable - there was some glue residue but no sticker.
Toyota dealer?
