Help to identify this leak
Crawforddd
I noticed this while under the car.
You can see it is routed from one of the belts if this helps to identify it.
I've looked through a manual I've got, but still can't identify what this component is. It also has hoses running to it.IMG_20200624_142417.thumb.jpg.1a05872b6fd570434d1b4e07b5e8110a.jpg
Any help would be appreciated
It looks like the power steering pump to me
edit.
Thanks for your comment
At the time, after fiddling with my suspension, I wondered whether the misalignment could cause such issues with the power steering pump. It may well have been there since purchase, but what are your thoughts on that?
I also noticed a spot on my steering rack. Anything to be concerned about?
Looking how wet that pump is, it's past its best, also looking at the colour of the fluid it has had it as well (should be a dark cherry red) if it was mine - drain the system, new pump and flush/change the fluid through a few times
the rack doesn't look horrible clean it up with some degreaser and keep an eye on it
