Front Brake Calliper Torque Settings
Misba
Hi there,
I was looking for the front brake torque settings for both the calliper gliding pins and mounting bracket bolts. I have a 2016 Avensis 2 litre diesel.  Any help will be much appreciated.
Thanks,
Misba.
The mounting bracket bolts are around 100Nm.  The slide pin bolts no more than about 25-30Nm - I always put a spot of threadlock on those.
Hi mrfixer,
Thanks very much for the info and quick response, now I can actually get started on the brakes☺️. Yes I got the threadlock and silicone grease for the pin glides as well.
Thanks very much for your time much appreciated.
Take care.
Misba.
