Tsport Mk1 Turbo Diesel Conversion
pio14343
You can drop pressure with the actuator, waste gate and DV the old school mechanical way
Block wise i would at least gap the rings if not drop the compression ratio
on stock internals 5-6 psi is about max, look at the old bolt on SC and Turbo kits
Sorry for those newbie worries.. I haven't turbo'ed cars before.. this is my first time ever.. I have realised just now that there is in fact a turbo yaris and a standard lol
Have cancelled that boost controller, hope it gets refunded quick so I can actually just order the maxxecu mini. Have applied to be quoted on one..
EMS performance can supply them for 800 with plug and play loom and base map loaded.
