2017 aygo instrument cluster
wheelerdealer41
Hello, I need to replace the instrument cluster on my 2017 aygo. The question I need answering is is it a simple plug and play to the donor part or will I need to get it paired up to the car? The mileage on the donor cluster is almost identical to the original.
2 minutes ago, G6-R said:
plug & play
Appreciate your reply,  thank you
Most cars have 5 different control units that hold the mileage
Sent from my G8341 using Tapatalk
but only when the old and the new one have a revcounter.
with the new cluster you wil see the mileage from this new cluster
your car is still under the toyota warranty
why not let them change it for you
It was smashed during loading of fence posts,  my 11yr old son!
its plug&play buy one and change it yourself. disconnect the Battery before beginning
https://www.onderdelenlijn.nl/auto-onderdelen-voorraad/onderdeel/kenteken/hz216t/modeltype/43010/onderdeel/instrumentenpaneel/onderdeelid/13567106/
here are some pictures from the front and the backside
2 hours ago, G6-R said:
its plug&play buy one and change it yourself. disconnect the battery before beginning
Thank you very much
make some pics when your changing the cluster alway's helpfull for athore people
Just to update guys the cluster arrived and fitted. Very simple fit and you were correct it's plug and play.  Everything working perfectly.  Thank you for your time and knowledge.
Kind regards
David
