help find a new air con compressor granvia 1995
brianhepb
looking for a replacement air con compressor the part i believe is 88320 it for 1995 granvia 3ltr
can anyone help me find a part please
88320 is what Toyota call a PNC "part name code" so all AC compressors start 88320-##### its the next 5 digits that individually identify the specific part. If you can post your Frame # I can get the exact part number.
Frame should start KCH1#-####### ( last 7 are all numbers )
thanks for your help its much appreciated the frame number is KCH10-0002071
Correct part number is 88320-26550 £801.83 + vat from Toyota, not shared with any other model in Toyota's range
hi. I have the same issue. Does anyone stock new a/c compressors in the UK for a granvia?
My frame number is rch11-0011019
  • 1 year later...
